2008 Polaris Sportsman 800 EFI
Old Oct 7, 2009 | 06:29 AM
cmharcou's Avatar
Default 2008 Polaris Sportsman 800 EFI
I have an 08 SPortsman 800 EFI. When I first start it and want to take off it wants to spudder and backfire on me sometimes it dies. It only has about 30 hours on it. Any suggestions?
Old Oct 7, 2009 | 12:19 PM
switzomatic's Avatar
Do you let it warm up for a minute on a cold start before taking off? They can be a little finnicky sometimes. I let mine warm up for a minute and take it easy for the first few while driving to make sure everything is properly warmed up and ready for abuse.
Old Oct 7, 2009 | 12:26 PM
chevyman142000's Avatar
Mine did the same exact thing before I got rid of it. Just let her warm up for a minute or two and sh will be good to go.
Old Oct 7, 2009 | 03:50 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes if it's a cold engine you willl have to give it a minute to warm up or at least feather the throttle while taking off. imo
Old Oct 8, 2009 | 09:30 AM
popoman's Avatar
efi... shouldnt need a warm up atleast mine doesnt. any codes show when you turn the key 3 times in 5 seconds? ive read some chaffing wires at the tps sensor cause some of these symptoms.
Old Oct 8, 2009 | 04:32 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
even a efi could put raw cold gas in to a cold engine and cause a little stumble. granted it shouldn't be very noticeable for very long. imo
Old Oct 8, 2009 | 07:08 PM
700 sportsman's Avatar
You don't happen to have a video do you?
But anyway, mine was doing similar things after a little water riding, or a good washing, and I blew out and die electric greased up my spark plugs, and put a fair amount in the plug boots, I did it, and after several rides, I put a little more in it, and it's been good for a long time
Old Oct 8, 2009 | 07:14 PM
UTU's Avatar
UTU
TPS setting could be a lil off causing this too.
Old Oct 8, 2009 | 07:25 PM
I forgot about adjusting the slack about 1/16" in the throttle cable, this can be adjust on the cable about half way down the cable between the throttle and the pod
Old Oct 12, 2009 | 07:27 AM
cmharcou's Avatar
Would new spark plugs help this? I have changed them before in a 2006 model and its a pain in the rear end. So I have been dreading changing plugs. The ATV and plugs are only a year old.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
RedRancher
Jul 10, 2015 06:36 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
