2004 Polaris Sportsman 600 knocking
Old Oct 12, 2009 | 05:30 PM
brandonorban's Avatar
Default 2004 Polaris Sportsman 600 knocking
this 2004 Polaris Sportsman 600 if fine at idle but when you give it throttle it starts to knock, the owner seems to think its a cracked piston skirt?
Opinions?
Old Oct 12, 2009 | 05:51 PM
dirtjunkie's Avatar
It could be a broken piston skirt, but doesnt sound like it to me.
Pull the topend off (pistons & all) & check the crank (big end) for rod movement. If that isnt it, most likely your main crankshaft bearings. Which would require splitting the cases to get to & replace..... Not an easy task
Some people have been known to use a stethoscope to locate the position of a knock either in the cylinders or in the lower end.
Old Oct 13, 2009 | 01:37 PM
how likely is it something to do with the crank shaft as i dont want to replace another one of them buggers. This isn't my quad but i might be buying it.
Old Oct 14, 2009 | 05:27 PM
dirtjunkie's Avatar
likely, its either the crank or the bearings if the noise is coming from the lower end.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
