XPLORER PLOW SETUP PIC request
anyone with a xplorer 400 4x4 (2001ish) with a plow, can you post pics of the mounting locations and where everything else bolts up, I pick up a plow and mount off of a sportsman told it would fit my xplorer cause they are the same frame, well apparently not...
Groundfx,
Are you having problems with the push tubes or manual lift? I purchased a plow, tubes, mount and lift from 99 magnum, look just like mine, however, I needed to buy a seprate mounting kit with manual lift and mount that attached to the frame. I sold the setup last year but still have the manual lift attachment for 99 xplorer.
My mounting plate attached with u-bolts to the square supports for the foot wells. The manual lift attached to the the support that the coolant res is attached to. I don't have my atv right now, but if you post some photos of your bike and attachments, I could probably tell you if it will work or not.
Good luck,
GH
Good luck,
GH
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
