clutch kit first?
Old Oct 20, 2009 | 10:26 PM
nc porider's Avatar
Default clutch kit first?
want to put larger tires on my 550 xp and a clutch kit but can't do both at the same time so would it cause a problem to put the clutch kit in first with the stock tires and then get my tires later when i have the money?
Old Oct 21, 2009 | 05:53 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would doubt you will have any issues by putting a clutch kit in before tires. it will just perform differnt w/ the kit in to help w/ power loss from oversize tires. imo
Old Oct 21, 2009 | 07:30 AM
rancher55's Avatar
What size tires are you planning to put on? If you are only going to 27" you probably don't need the clutch kit. Any bigger though and I would say the clutch kit first then tires.
Old Oct 21, 2009 | 08:02 AM
nc porider's Avatar
probally 27 grim reapers fronts are 27 lbs and rears are29 which i think are not only larger but a lot heavier than stock
Old Oct 21, 2009 | 10:09 AM
EPIChad's Avatar
The answer will vary depending on what brand of clutch kit you go with. Also depends on each particular model because some machines will have bigger differences in clutching between stock size tires and oversize tires. On your machine through EPI you can order the stock tire kit and run it that way until you get the bigger tires. You should only have to change one thing on your machine to make it work with the bigger tires as long as your staying in the 27-28" range. If you go bigger it will take a bigger change.
Old Oct 21, 2009 | 03:57 PM
700 sportsman's Avatar
I would go with tires, and then if you have a noticeable power loss, get springs, or a whole clutch kit if it's bad
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
