1996 400 polarissporstman
Old Oct 20, 2009 | 05:37 PM
doug13452's Avatar
Unhappy 1996 400 polarissporstman
How do you test the coil? I went from positive to ground and got continuity??
Old Oct 21, 2009 | 06:12 AM
ftwflh's Avatar
I have a coil listed on Ebay for this.Here is the Ebay number
220497700858
Old Oct 21, 2009 | 05:59 PM
doug13452's Avatar
Default 1996 polaris sportsman
thanks, DO you know how to test the coil??
Old Oct 21, 2009 | 06:06 PM
doug13452's Avatar
Lightbulb
I see the coil on ebay. If you go from the power terminal to the ground do you get continuity?
Thanks,
Old Oct 21, 2009 | 08:34 PM
If you get less than 0.3 ohms resistance from primary to ground when coil is at room temperature then possible coil problem. Dont forget to check wire itself for cuts and ground wires also.. From my experience dont have many coil problems, if no fire condition usually stator related. Plug caps should be around 5000 ohms,can short out also,but rarely.
GregM
Mar 6, 2018 06:53 AM
chewy78
Sep 8, 2015 10:37 AM
slowgsxr97
Sep 8, 2015 04:37 AM
GregM
Jul 29, 2015 09:41 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
