oil clarification
Old Oct 23, 2009 | 01:15 PM
Mic_'s Avatar
Thumbs up
Originally Posted by Wheels47
If you go to a polaris dealer they will provide you with all their new fluids. The Newer models can't use the older fluids but the older models can use the newer fluids. I have a 99' 500 and changed out all the fluids with the new ones. I will have to research that the new gear fluid is. I haven't had a problem.
I think that answers my question...new part s# for new fluids that ARE complatible with my 500
Old Oct 23, 2009 | 03:40 PM
TLC's Avatar
TLC
The ONLY fluids the new and older 500s do not share is the Hilliary fluids,the fluids for the front diff type AWD drive is not like the twin hub type AWD drive. Tranny fluid, engine oil, coolant still the same thing. Polaris makes a new 2w-50 oil for there twin cyclinder motors now,but there singles still and always have used 0w-40.
Old Oct 23, 2009 | 11:14 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Be careful. The front diffferentail on a 1999 - 1998 is 80W or 90W gear oil.
Old Oct 24, 2009 | 07:48 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
I have a 2000 Ranger 6x6, and use the 0-40W Synthetic from L&M Fleet and Supply, also run the Fram oil filter-#6017. Run the Polaris hub fluid which has new part#'s and is used on some other application, can't remember off the top of my head at the moment. Run Polaris gear case oil
Old Oct 24, 2009 | 08:25 AM
  #15
TLC's Avatar
TLC
That goes from 1996-2004 from 2004.5 and on the front diff is the NEW engagement point of the front wheel drive system not the two front hubs any longer,so they use the Polaris AWD Hillary fluid not regular gear oil anymore in the diff.
playnsnookie
1) Engine problems..
Jan 17, 2015 04:58 AM
TreadLightly
32
Aug 7, 2011 10:07 PM
pwrshock
Feb 12, 2011 01:12 PM
Dynamo55b
Aug 26, 2010 02:13 PM
Nordikwolf
Jun 24, 2002 02:18 PM
