oil clarification
Old Oct 21, 2009 | 07:53 AM
Mic_'s Avatar
Exclamation oil clarification
Hi all
I have a 1999 polaris 4x4 sportsman 500 and wanting to do ALL the fluids.
But i get different part #s for the oils (dealer vs my owners manual vs seen on line)
Can some one help me?
looking at:
front gear case
front hubs
rear trans case
thanks
Old Oct 21, 2009 | 07:58 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Check out the "many" threads related to your topic.
Old Oct 21, 2009 | 08:08 AM
Mic_'s Avatar
yes there is many!
with many opions and differences
but i was hoping some one /some where it is summarized.
Old Oct 21, 2009 | 09:29 AM
TLC's Avatar
TLC
0w-40 full synthetic ONLY. My Clymer's SP500 manual stated 10w-30 ,but they also said to take the two clutch pulleys off to remove a starter and remove the front bumper,front fenders and rad just to change the Fan! I don't believe everything I read from it any more. LOL
10w-30 LOL no wonder people had to change there cams lobs so much back then.
Old Oct 21, 2009 | 12:18 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
0w-40W sythetic for sure. I use Mobil1 (0w-40w) oil and a NAPA Filter (same as WIX). I use the Polaris brand hub and transmission fluids.
Look at a POLARIS manual - they all say 0w-40w synthetic for the engine.
Old Oct 22, 2009 | 11:35 AM
Mic_'s Avatar
THIS IS WHAT I HAVE AMMASSED SO FAR:
So glad you asked that question. I have a 98 model, and I'm looking for the same info.
I found this information online, but is it true?
FRONT GEARCASE OIL
Polaris Premium Hub Drive Fluid (#2781654) [[ I FOUND THIS TO BE #2876160 & THE MANUAL SAYS #2871653 ]]
Substitutes:
Amsoil Automatic Transmission Fluid (ATF)
Amsoil STL Shock Therapy #5
Any Type F ATF
Dextron III Trans fluid
TRANSMISSION OIL
Polaris Premium Synthetic Gearcase Lubricant (#2783602) [[I FOUND THIS TO BE #32878068 & THE MANUAL SAYS #2871478 ]]
Substitutes:
Amsoil Series 2000 Synthetic Chain Case Oil (TCC)
REAR GEARCASE OIL
Polaris Premium Synthetic Gearcase Lube (or GL5 80-90 weight gear lube)
(I assume the stock fluid is #2781653, Gear Drive Fluid)
Substitutes:
Amsoil 80w-90 Synthetic Gear Lube (AGL)
Amsoil 75w-90 Severe Gear Lube (SVG)
[[ I FOUND FRONT HUBS TO BE FROM TEH MANUAL #2871654 ]]]
Old Oct 22, 2009 | 05:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
alot of the pn#'s you have in the manual i'm guessing has been superceeded to newer oil's from polaris.
Old Oct 22, 2009 | 07:30 PM
Mic_'s Avatar
Question
hence my confusion ??????????????????????
Old Oct 23, 2009 | 09:20 AM
TLC's Avatar
TLC
FRONT GEARCASE OIL
Substitutes:
Any Type F ATF
TRANSMISSION OIL
Substitutes:
REAR GEARCASE OIL
Substitutes:
Are you talking about a 500? The tranny is the rear gear case its a all in one unit. The tranny fluid is both the fluid for the tranny and rear drive,there is no rear diff fluid on the 500 with IRS.
The only differences between the first SP500 in 1996 and the newest 2010 SP500 in fluids is the older ones had drive fluids for the two Hilliary's in the hubs while the new ones have it for the single Hillary in the front diff now.
Old Oct 23, 2009 | 12:56 PM
Wheels47's Avatar
If you go to a polaris dealer they will provide you with all their new fluids. The Newer models can't use the older fluids but the older models can use the newer fluids. I have a 99' 500 and changed out all the fluids with the new ones. I will have to research that the new gear fluid is. I haven't had a problem.
