Polaris 500 H.O.
Old Oct 24, 2009 | 08:36 AM
leopold22103's Avatar
Default Polaris 500 H.O.
I bought a 2009 500 H. O. last week, are they per-wired for a winch???
Old Oct 24, 2009 | 08:58 AM
bitterfitter's Avatar
My 05 500HO was pre-wired, but I can't say for sure if your 09 is. I think all the full size Sportsman's are though. What kind of winch are you thinking of?? I loved the warn on my HO, not so much the Polaris winch on my XP.
Old Oct 24, 2009 | 09:07 AM
mtpockets's Avatar
A HUGE congrats on the new 500 purchase!! (I just did the same thing)
Can't help ya on the pre-wiring BUT I did buy a Polaris Warn 3000lb winch and the dealer is installing it today. If I think of it I will ask them if it was pre-wired when I go later to pick it up.
Again congrats!!!
Old Oct 24, 2009 | 09:31 AM
700 sportsman's Avatar
Yes they are all pre wired, there is a small metal shield up under the right front fender, and the wiring is right up there too with a rubber cover that says winch wiring right on it, and then you also need to connect the wire that is under the left rear fender to the posotive battery terminal, and then you'll be good to go
Old Oct 24, 2009 | 12:52 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes they are prewired.if you do search you will find alot of post on this. i even put pics/ of where the plate^^^ he is talking about is located.
Old Oct 24, 2009 | 03:52 PM
where can I find the pictures??
Old Oct 24, 2009 | 05:32 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i'm too lazy to search for them so i'll just repost them .lol
Old Oct 24, 2009 | 09:07 PM
THANKS !!!!!!! I'll look in the morning!!!!!!!!!!!!!!!!!
Old Oct 24, 2009 | 10:12 PM
chuck_raduenz's Avatar
the wires are under the right side fender behind the front wheel behind the steel plate. the contractor gets mounted to that plate. and as stated above you will need to attach the positive from the winch cable to the battery. it had red heat shrink on it. or in my case it wasnt long enough so i wired it to the battery side of the solinoid. the winch side of the cabe says: winch wireing. there are also igntion sorace for the red wire that comes from the handel bar switch. ill also add my pics of when i installed mine last yr. mine is a 08 500 sportsman.
do not connect anything to the red circle. or white wires.
your ign wires are circled in white. the wire colors are orn and orn/white. there 2 wires per plug.
Old Oct 24, 2009 | 10:13 PM
stendori think its time to make a new sticky!!!
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
ltrmc02
Jul 22, 2015 04:50 AM
