1993 350l ignition switch wiring
also i think you could pull the starter bendix drive(if thats what causing the starter to drag, i would think it is) by just removing the pull start and not having to remove the starter... problem is then you have to remove the flywheel to get the bendix out... pick your poison lol... myself i didnt want to risk damaging anything with the stator/flywheel so i just took it out the bottom.
ranvette
07-04-2015 06:13 PM
