H.I.D Lights help
Old Nov 24, 2009 | 09:44 PM
Predasaurous's Avatar
Default H.I.D Lights help
i installed sum hid light into my polaris predator but , they both cant fire up unless full battery and it kills my battery , would a relay help me out , a new and bigger battery (i got stock) or any way i can upgrade my charging system?
Old Nov 24, 2009 | 10:03 PM
HeftyLefty's Avatar
Check if your machine is charging your battery. Stator output at 1500 rpm should 14-15 volts. Load test your battery too. HIDS actually draw less from battery than regular headlights, so something is wrong somewhere.
Old Nov 25, 2009 | 01:42 PM
zendlodj's Avatar
Default hid
HeftyLefty makes a good point. Last year my lights suddenly went berserk one night, I put the battery on charge and the next morning everything was working so I blamed the battery. A few hours later, same thing, lights blinking of and on. I tested the output of the stator, it was good, but next to no ouput from the voltage regulator. I wouldnt have noticed it until the machine wouldnt start if the extra load the lights put on the battery hadnt started me looking. There's a lot of posts on checking your stator, I dont remember where I found them, but take a look at it
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
