Scrambler Motor-Will it work
Old Dec 11, 2009 | 08:43 PM
tonythom's Avatar
Default Scrambler Motor-Will it work
Will a 500 scrammy motor work on an 03 trailboss, Any idea what problems to expect on the change over. Thanks Tony
Old Dec 11, 2009 | 09:11 PM
700 sportsman's Avatar
well, you'll need the electronics for the scrammy motor, and I'm not sure on the clutches, but I think you would have to use the scrammy primary for proper engagement and what not
Old Dec 12, 2009 | 07:41 AM
eggenz7's Avatar
unless you change the engine and tranny together you will be lookin at some serious clutch tuning
Old Dec 12, 2009 | 08:38 AM
ftwflh's Avatar
I wouldnt mess with changing motors like that you are opening a can of worm.You will need the radiator and parts for that along with sensors different motor mounts and a ton of other things.It would be cheaper,easier and faster to just buy a 500 Scrambler or rebuild the 330 motor.RcR makes a good top notch big bore kit for those and has reasonable rates if you send him the motor.
Old Dec 12, 2009 | 05:36 PM
4getful2's Avatar
he's doing my 400 2-stroke and it should be sent to the house monday or tuesday.
$280. for a bore ,piston,rings and top-end gaskets ,just to give you an idea
hugemoth
Jul 20, 2020 03:28 AM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
Chocobamofo
Jul 10, 2015 07:46 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
