2002 Polaris Sportsman 500 electrical problem
Old Dec 14, 2009 | 08:29 AM
Bamaman17's Avatar
Default 2002 Polaris Sportsman 500 electrical problem
I bought a battery for a friends 2002 Polaris Sportsman 500 that he recently purchased. Someone had taken the Regulator off so i put it back on when i got it. With the new battery and regulator in i went to start it but nothing,no lights no life. Will the regulator cause this or is there another problem?
Thanks in advance from Bama!!
Old Dec 14, 2009 | 12:17 PM
Kerbbirds's Avatar
Get a multi meter and start following the positive cable from battery, could be bad connections at selenoid or starter.
Old Dec 14, 2009 | 12:22 PM
Bamaman17's Avatar
Kerbbirds-
Thanks for your help!!
Bamaman17
Old Dec 14, 2009 | 05:57 PM
boba's Avatar
Had a similar problem. All it was was a bad connection on the Earth lead from the battery.
Old Dec 15, 2009 | 06:52 AM
Bamaman17's Avatar
I got power to everything now i have starter problems. Thanks for your help.
Old Dec 15, 2009 | 09:30 AM
TLC's Avatar
TLC
Your starter brushes maybe sticking and just need a cleaning. It worked out like that for me.
Old Dec 16, 2009 | 01:32 AM
boba's Avatar
Any power to the starter at all.
Usually one of two things Starter Brushes need repalcing or cleaning.
If no power to the starter bridge across the two terminals on the starter soleniod and see if that works.
If it cranks over then the solenoid needs replacing. Cost not much more than a family pizza
skittero
35
Mar 1, 2019 12:39 AM
gfl0224
Jun 27, 2015 06:52 PM
yellowpolaris
Jun 21, 2015 11:13 AM
DOAinNY
Jun 11, 2015 10:34 PM
Dakosk
Jun 6, 2015 05:37 PM
