Pull start rope ?
Old Jan 19, 2010 | 09:03 PM
Originally Posted by ofie
Discussing the pull rope, anybody have the pull rope coil work so hard to pull. We always use the battery start but, would like to fix this issue with the hard pull.
Thanks, (1999 Polaris Magnum)
The best way to pull start the 500 engine is to grab the handle with both hands and jerk like hell! This way it wont slip back and rip your hand. This is the ONLY way I will try to pull start one any more! Had the handle rip out of my hands too many times until I wised up. It doesnt matter even if you try position piston just past tdc or just before to help take the load off,it can still bite you! OPT
Old Jan 20, 2010 | 10:25 AM
TLC's Avatar
TLC
You may have a decompression problem, the 500 motor has a decompression valve,my SP500 is easier to pull over then my 350 Big Bear was because of it.
Old Apr 7, 2011 | 05:00 PM
ofie's Avatar
what do mean by a decompresion valve?
Old Apr 7, 2011 | 05:47 PM
OLD POSTS,but to answer your question,its not a valve,but a decompression lever on the end of the cam that opens the exhaust valves a little (lowering compression) when trying to electric start or pull start. The500 can still rip the pull handle out your hands if not careful. OPT
Old Apr 7, 2011 | 06:45 PM
  #15
Kerbbirds's Avatar
you ought to try mine wth 11.5 to 1 compression, I keep a good battery and starter in it cause likeOPT said it will get you
Dammar
Nov 14, 2015 07:41 AM
DOAinNY
Jun 11, 2015 10:34 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
