Can ATV tires be mounted by hand?
Old Jan 20, 2010 | 11:28 PM
mdvctry's Avatar
Default ATV Tire Changer
I did the same thing a couple years ago so I would be able to change/fix tires on ATV trips. Only had to use it once, but it paid for itself then.
Originally Posted by bentarrow
After paying $26 each at Discount Tire to mount 2 I went to Harbor Freight and bought a tire mounting machine for the other 2. Small enough to take with me and mount on the ATV trailer if needed, large enough to do 14 inch trailer tires if needed while camping. It cost $56, almost the same cost as having them mounted. I looked at spoons but a good set cost $20 or $30.
Old Jan 21, 2010 | 12:21 PM
The Malt King's Avatar
The trick method mentioned in post#9 is remarkably simple. There are many videos on you tube demonstrating the process. I would review those before making up your mind.
Malt King
Old Jan 21, 2010 | 12:39 PM
psenitrohunter's Avatar
Originally Posted by stendori
i've done a few my self. there alot harder to break down the old tire then actually mount the new ones.
Use a second vehicle to break the bead. It is a lot easier with two people, but all you need to do is lay the tire down and then drive a car or truck onto it. It's best to stand out and adjust the tire while someone else drives onto it slowly as you need to be very close to the rim but not hit it. If it doesn't break the bead, one or two good stomps on the exposed part of the tire will usually get it to let go. Then have the other person back off, flip it over, and do the same for the other side. Sometimes its helpful to lay a board down on top of the tire you are breaking down and then drive onto the board like a ramp. Like a 2x8 or 2x12 just for a less forgiving surface. This is about the second easiest way I have found to breaking them down. The first being the bead breaker on a tire machine.
Old Jan 21, 2010 | 12:52 PM
TLC's Avatar
TLC
Our near by Tire shop charges $10 per tire so I never really was interested in trying.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
MNatv89
Aug 12, 2015 06:00 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
