Snow Plows - Front or Center Mount?
Old Feb 11, 2010 | 07:52 AM
  #21
FunRide's Avatar
Originally Posted by awsume800efi
I just bought the warn pro vantage with 60" blade it is a front mount plow with no ground clearance loss at all hooks and unhooks very easy and seems to be very sturdy i know we get lots of snow in ND and it pushes alot of snow
Wow...60" blade is huge. That'll be some tough going in wet heavy snow. That's just so much snow to push. I guess if you attack storms with a couple of passes, it makes it a lot easier.
Can you post some pics of the Warn installed and how it angles? What was the cost, if you don't mind saying?
Old Feb 11, 2010 | 08:04 AM
  #22
JCDEYO25's Avatar
Malt King...
I think one of your concerns is ground clearance due to mounting brackets when not plowing...Just be aware that even with the push tube, center mount, there is a bracket that bolts to the frame as well...Mine only hangs down slightly but I take it off after plow season...Mine is the Cycle Country mount...Just a heads up...
John
Old Feb 12, 2010 | 11:56 PM
  #23
awsume800efi's Avatar
Default Pics of the plow
sorry these r not the best pics i took them with my phone and thankfully we don't get a whole lot of wet heavy snow here or i think it would be a bit much, for sure power is never an issue and i weigh 300 plus and have 28 589 m&s tires on but still run out of traction in real deep snow it has settings on the plow to adjust angle i have mine maxed seems to work real good
Attached Thumbnails Snow Plows - Front or Center Mount?-phone-feb-2010-027.jpg   Snow Plows - Front or Center Mount?-phone-feb-2010-028.jpg   Snow Plows - Front or Center Mount?-phone-feb-2010-029.jpg
Old Feb 13, 2010 | 12:05 AM
  #24
sorry it was about $550 dollars for everything i am sure it could be found cheaper but i like to go through my local guys so paying a little extra doesn't bother me also all you have to do when you want to unhook or hook up is pull the two frame pins they are just pins with little srpings on them and another pin for the winch rope and your done takes a minute maybe also i put a short synthetic rope and the bigger fairlead on soon after as my cable only lasted for a week or so. the rope seems to work better anyways cause you don't have 50' of cable if you want more pics i sure can go take some and post them
Old Feb 13, 2010 | 06:36 AM
  #25
Thundercat1000's Avatar
I have the front mount on my Thundercat but in order to change the front diff fluid its got to be taken off...(Its WARN and its a pretty poor design for my application..I know they are not all like that tho) And believe me the installation of it was not easy...(I actually had to modify it even tho it was the correct part no.) I am taking it off this spring and leaving it off until next fall...My buddy has a center mount on his Foreman 500 and it hits on EVERYTHING!...Thats why I didnt go with the center mount..
Old Feb 13, 2010 | 06:38 AM
  #26
I also have the 60" WARN blade and pushframe...
My blade also has a weird bend to it right out of the box
I expected better things from WARN
Old Feb 13, 2010 | 01:11 PM
  #27
i guess mine seems to be good and installing the plow frame was a little time consuming but not hard and it never needs to be removed as its tucked away pretty good
baysport
Jul 23, 2015 11:37 AM
WilliamBos
Jul 22, 2015 04:20 PM
RticKwad
Jul 21, 2015 03:00 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
cornermike
Jul 8, 2015 11:44 PM
