sportsman 700 dead...no power?
Hello, went out riding this week. while going down the trail the machine bogged down and quit running. There is no power at all. I submerged it in a pond back in november. I changed all fluids and put new plugs and she was running great. Do you think its the ECM? I tested the battery and solinoid and there is power to both. Any help will be appreciated. Thank You, Dan
Not getting any power, start with the battery and move forward. Mine did that and it ended up being the battery wires were not tight, not loose, just not tight. I cranked them down snug and problem never came back. I would take your cables off, make sure there is no dirt or corrosion from you dip in water and snug them back on tight. If you have power from there go to the next connection.
