Starting problem -08 Sportsman 500EFI
My 08 Sportsman has stopped starting with the ignition switch. While plowing snow this winter it started acting up and only starting intermittently. Now it won't start with the switch at all? The speedo/dash all come on all other electrics seem fine and a pull on the starter rope fires it up, but nothing happens when I turn the ignition switch,dash comes on self check runs, everything appears fine - no starter - no click . Checked wires in headlight pod, found nothing ? moved shift lever, tried holding on brake, still nothing. any ideas?
whitty
67
02-24-2021 02:52 PM
