"UPDATE" 2005 700 sportsman "overheating"
#21
Remove the radiator cap and jack the front end up with the tires off the ground. Let the fan cycle on and off several times,top off the coolant and replace the cap. See if this helps first if trapped air is causing the problem.
Shifts
14
Jul 13, 2015 08:41 AM
05, 2002, 2005, 700, 800, atv, fan, operation, overheating, overheats, plowing, polaris, sportsman, thermostat, troubleshootting
