polaris sportsman 500 h.o moves by itself in gear with no throttle
Old Mar 8, 2010 | 07:37 PM
TLC's Avatar
TLC
Originally Posted by sk8er289
how should i adjust the linkage and know where its right
Our 97 SP500 was grindy and hard to put in forward and then would pop into neutral easily on its own. I adjusted the rod just a little and it work perfect again.
I just tuned the adjuster with trial and error until it worked. No need to tighten the lock nuts until you find the correct adjustment to help speed things up.
Old Mar 8, 2010 | 09:03 PM
Jocko's Avatar
Check out this thread too. there is a video I posted which shows the secondary clutch at idel. If it is moving, then that is what is causing your machine to creep.
http://forums.atvconnection.com/pola...00-clutch.html
Old Nov 10, 2018 | 09:54 AM
Chris Mange's Avatar
Default See if your front tires spin in the mud. Like. for mudd sling from
i just put a stator in and the quad creeps by itself at idle and the shifter gets stuck wheni put it in 1 and try to go to reverse or just high gear to reverse. any sugestions. and i was wondering, my front right tire never spins when it is in awd. is that normal? its a 2002
Whatch the front tire when going threw a mud pit. See if they spin up mud when your spinning. Some. 4x4 on demand 500. Only engage awd when your rear tires spinn faster then your front like when it's start slipping it engages. Or. When the front drive is faster then your front wheels it engages a electro magnetic system to engage. If not Check your wiring and your wheel bearing. Or aka hillard clutch
Old Nov 10, 2018 | 07:43 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
You're giving advice to someone who hasn't posted in any part of the forum in 8 1/2 years. They must have figured it out by now.
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
yellowpolaris
Jun 21, 2015 11:13 AM
DOAinNY
Jun 11, 2015 10:34 PM
May 27, 2015 11:15 AM
