92 Trail Boss 350 replacing the pull rope?
Old Mar 15, 2010 | 11:52 PM
farrier403's Avatar
Default 92 Trail Boss 350 replacing the pull rope?
I replaced the pull rope. It worked but when the bike started the rope would not recoil... I have tried again since, I turn the cover 3 turns clockwise like it says in the manual and still no luck.. What should I do?
I have to start it by wrapping the rope around the plastic wheel...
Old Mar 18, 2010 | 08:16 PM
Boatnut's Avatar
Sounds like your recoil starter return spring is either broken or something is not set up quite right. Check it before you fully install it next time. Spring should retract rope after you pull it out.
Old Mar 18, 2010 | 08:21 PM
Mr. Fancy Pants's Avatar
Is your pawl gear sticking? Does your model have a pawl gear inside the recoil?
wildbill59
Jun 20, 2015 02:26 PM
DOAinNY
Jun 11, 2015 10:34 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
