CV boot/bearings problem
Old Mar 25, 2010 | 02:05 PM
Cookie66's Avatar
Question CV boot/bearings problem
CV boot/bearings problem-rsz_1cv_boot.jpg
CV boot/bearings problem-rsz_cv_boot2.jpg
Can some one identify this problem? There is a clicking, and I think its the bearings. These are some pic. of it.
The atv is a 2002 Polaris Sportsman 400.
Old Mar 25, 2010 | 02:35 PM
ardakota's Avatar
clicking going backward is common problem from what i read but you really need to get those off and clean the dirt and grease out of those cv joints and put new boots on them if they arent ruined by now looking at the mud and dirt on your wheeler.
Old Mar 25, 2010 | 02:54 PM
Cookie66's Avatar
It clicks whenever the atv is moving.
Old Mar 25, 2010 | 03:34 PM
switzomatic's Avatar
Chances are pretty good if you've been running it like that with torn boots then the cv's are trashed. Best bet is to replace the axle since replacing both ends would cost almost as much(unless you go with the cheap aftermarket ones on ebay which probably won't hold up). Looks like you mud a lot so my advice is to get some beefy a-arm guards and keep an eye on those boots. Much cheaper to replace a torn boot than an entire axle.
Old Mar 25, 2010 | 03:41 PM
Cookie66's Avatar
Are the bearings already bad, because of the clicking? Also, how would I replace them? Or were?
Old Mar 25, 2010 | 05:52 PM
waynaferd's Avatar
If they're clicking, I would guess yes. There's a sticky up top on how to replace the rear CV's on a Sportsman....check it out to get an idea of what needs to be undone
Old Mar 25, 2010 | 07:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if it's clicking, 99% of the time the cv joint is bad. once you take it apart you can check the bearings to see if there bad, but they usually don't click from a bad bearing. also putting new grease in after cleaning w/out replacing the cv joint won't work for very long if at all unless your lucky. imo
Old Mar 25, 2010 | 09:49 PM
Cookie66's Avatar
I have one more question, about how much will it cost to get the CV joint replaced at a ATV repair shop?
Old Mar 26, 2010 | 07:06 AM
Kerbbirds's Avatar
Depends on the shop, you can figure one hour per side labor plus the price of the shaft.
Old Mar 26, 2010 | 07:08 AM
Kerbbirds's Avatar
Call the c-v man,1-800-338-2326, he has what you need at a lower price than the dealer.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
