please help 94 trailboss 250 problems
Old Apr 7, 2010 | 01:59 PM
polarisben29's Avatar
it only happens after 15min of riding. not sure if i should sell it as is or put more money into it? any other ideas i could try? would appreciate any and all ideas
Old Apr 7, 2010 | 04:41 PM
I had a problem with a stator when I had a Xplorer 250. It would stall or just act weird once it was warmed up. Just a thought.
Old Apr 7, 2010 | 08:03 PM
randyneff6971's Avatar
Originally Posted by tv4fish
Don't get your hopes up on the gas cap vent Ben - If you were creating a vacuum in your gas tank - it wouldn't make any difference if the engine was hot OR cold.
if the gas vent line is pinched, it might take a few minutes of riding before a negative pressure is created in the tank making you think it only happens once its warm. its not likely to happen when the quad is cold because it hasn`t had enough demand from the tank to create a negative pressure. It might not happen at all if the quad is running at idle because the air could pass the blockage in the vent line at a slow pace. To eliminate the vent line issue loosen the cap and go for a spin.
Old Apr 8, 2010 | 08:25 AM
so i cleaned out the air box and filter, put in a new oil filter, and took the breather line from the gas tank which was under a cap on my handle bars and put it out, i drove it for two hours and didnt act up once even was riding hard. when i got back i did notice i am leaking oil where the head gasket is i think. the gasket above the cylinder not sure how hard that is to replace or if its more than just a gasket any ideas?
Old Apr 8, 2010 | 01:03 PM
  #15
tv4fish's Avatar
Hey Ben: No.1 - Don't go back to the dealer that told you that you needed to bore it out No. 2 - You got lucky on your "easy" fix No.3 - Yes - that is the head gasket and it should be easy to replace, BUT - maybe you just need to tighten the bolts/nuts that hold the head on if they're loose? Try that first. IF you need to replace the head gasket - just remove the nuts/bolts that you need to to lift off the head (not the cylinder - just the head), then just check the head gasket to see where it's been leaking. If it's shot - replace it.
Old Apr 8, 2010 | 02:12 PM
  #16
ya i am done with that dealer for sure. i bought a gasket just in case. would it be a good idea just to replace it anyways or if tightening the bolts works just leave it? thanks again for all the input really appreciate it.
Old Apr 8, 2010 | 02:53 PM
  #17
tv4fish's Avatar
Ben: Since you have the new gasket already - I would go ahead and replace it. When you have the head off -- push the piston down to the bottom and just check for any grooves or scratches on the sides of the cylinder - there shouldn't be any.
Old Apr 8, 2010 | 07:01 PM
  #18
I`m happy you solved the 1st problem, I also agree since you have the gasket go ahead and replace it. if you didn`t already have 1 (new gasket)trying to tighten the bolts might have done the trick. don`t forget to tighten the head bolts in the proper sequence and torque. Once thats all done welcome to 4wheelin and get ready for the next thing to fix
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
