gasket leak
Old Apr 6, 2010 | 06:39 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Default gasket leak
Yesterday I notice my sp500 (51hrs.) making a squeeking noise and found that the intake manifold gasket had a small break in it. I've got it patched up for now with hi-temp RTV. Is this an issue with the 500's or just a fluke? And what would you guys suggest for a new gasket? I considered taking it apart and redoing the gasket with rtv or getting gasket material and cutting a new one. Polaris want's $15 for a new one which is insane for a tiny gasket. And which type of gasket material would be best to match OEM if I go that route. I was thinking a poly/rubber type but whats your opinions.
Old Apr 6, 2010 | 07:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you said this is the intake gasket and not the exchaust headed gasket? what year is the bike? i know there is the rubber boot for the intake(by the carb) and there is a gasket on the exhaust for like $17. and you might be able to use hi temp rtv or maybe make your own if you bought hi temp gasket materail.imo
Old Apr 6, 2010 | 07:36 PM
this is a 2007 sp500 EFI. It is the gasket between the intake elbow (aluminum) and the block or jug if you will. The injector is mounted in this same elbow.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
tysonbully
Sep 28, 2015 02:30 AM
wrencher82
Sep 24, 2015 03:39 PM
