transmittion problem?
Old Apr 6, 2010 | 09:51 PM
Scott267839's Avatar
Default transmittion problem?
I have a 00 Magnum 325 that grinds while putting into gear from ‘N’. I have replaced the pri spring and belt. I even keep old belt on it that has over 2" of play and it still grinds. The secondary clutch runs all the time while in 'N', even with lowering the idle down to where it will die. I have removed belt and spin the secondary clutch. It spins free. When I spin it it just keeps spinning. The belt is so lose and by it just setting on the primary drive it spins the secondary. Is it normal for the transmission to spin freely or should it have a little resistance to keep it from spinning just by belt seating lose on pri. clutch drive?
Old Apr 7, 2010 | 03:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the secondary will spin freely when in neutral w/ out the belt on. does this bike have the ebs on the primary? sounds almost like a bad ebs bushing and the bike would want to creep ahead while in gear. the engine mounts may be broke or out of alignment. imo
Old Apr 7, 2010 | 05:10 AM
No ebs on this. It is the correct distance between Pri and secondary clutches and belt is riding in center of pri clutch. (not rubbing on edges). Just the weight of belt laying on the center of pri. is allowing the belt to spin the secondary. That is how freely the secondary spins.
Old Apr 7, 2010 | 05:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
how much belt deflection do you have?
Old Apr 7, 2010 | 08:57 PM
I checked for broke engine mounts today. They are fine, not broke.
Belt deflection: old belt has 2"+ and new belt has right at 1 1/2" but I had removed a washer and got it within limits. I have since put washer back in because of the grinding issue.
Old Apr 8, 2010 | 03:51 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it sounds like w/ 1 1/2" is about right. so does it still grind w/ the washer back in?
Old Apr 8, 2010 | 05:36 AM
Per manual deflection should be 1 1/8 - 1 1/4. Yes it grinds with the washer back in. I think I'm going to recheck the shift linkage adjustment to see if it is off alittle to see if it changes anything.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
