wider rear tires for my scrambler
Old Apr 12, 2010 | 07:32 PM
rescueranger778's Avatar
Default wider rear tires for my scrambler
i was looking to put new tires on my 97 scrambler 500, i was looking at the bear claws because i like the tread pattern and the price but the problem is the stock rear tires on the scrambler are 22x11x10 and the bear claws comes in a 22x12x10. so the question is can the stock rims fit the 12in wide tires. every where i check it keeps changing so any help will be great thanks
Old Apr 12, 2010 | 11:30 PM
96scrambler400's Avatar
I had 12" tires on my 96 Scrambler with stock rims.They fit fine
Old Apr 13, 2010 | 04:30 PM
4getful2's Avatar
i put the 22x12x10 on my sport 400(2 wheel drive,2 stroke version of yours) on the stock rims.you'll really like the bearclaws,you'll be able to go farther in 2 wd than before. the tires wear flat but you can tell the rim is almost too skinny for the tire,at the time i couldn't find any wider than stock rim width,you might be better off finding the 22x10x10 bearclaws.
on stock rims w/4lbs. air the 22x12 is 21" tall
Old Apr 13, 2010 | 09:02 PM
Steve L's Avatar
I put 26x12x12 on 7.5 inch rims. The look kinda round but work just fine. They were a bitch to mount even with the tire machine at work.
Old Apr 15, 2010 | 10:29 PM
thanks for the help
Bratman2
Aug 6, 2022 01:42 AM
DeFox500
Jul 26, 2015 06:32 PM
rcappie4
Jul 18, 2015 07:51 AM
maxjung
Jul 13, 2015 05:11 PM
rcappie4
Jul 10, 2015 04:54 PM
