Ignition problems
Old May 14, 2010 | 04:15 PM
straks922's Avatar
Default Ignition problems
I have a 2005 500 sportsman. The battery is good, I've replaced the magnetic relay and I still get a clicking noise when I try and start it. Any ideas where I go from here?
Old Jun 7, 2010 | 11:37 AM
Steeves's Avatar
You should do a keyword search on this site for starter problems and you will come up with a few things to check and help you out in the future.
Old Jun 9, 2010 | 05:53 AM
chuck_raduenz's Avatar
get a volt meter check for the same voltage as the battery at the starter battery cable. or just jump the battery cables at the starter solinoid see if it will turn over. if no go. its more than likly a stater issue.
Old Jun 9, 2010 | 06:08 AM
TLC's Avatar
TLC
Mine would only click when I tried the starter, turned out to be a sticking brush inside the starter, I took it apart and cleaned and freed it up, been OK for 3 years now.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
greg74
Sep 10, 2019 03:03 PM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
