Tire size question
Old May 25, 2010 | 01:43 PM
tw1st3d1's Avatar
Default Tire size question
OK, this question may sound simple to u gurus, I know that there is supposed to be a difference in the height of the front tires and the rear tires for the 4 X 4 to work correctly, but I am trying to figure out how much of a difference there is and which has to be taller, the front or the back?
This is for a 1993 350L. I just recently purchased some used 27" Gators for a good price. The guy stated that they were off of his 93 350L so I assumed (I know) that it would be easy to figure out. The 27 X 8 X 12 went in the front, and the 27 X 12 X 10 went in the back. But not sure if it looks right, the fronts are taller than the backs. But I would figure that the skinnier tire goes in the front?
Any help would be really appreciated,
Jeff
Old May 25, 2010 | 04:33 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you would be correct on the fornt and rear tires. the tire size-27"x8"x12"=27" is height,8" is the width,10" is the rim size. on the older bikes the rear rims where smaller but the over height tire is the same. the 8" is for the width, which would be narrower up front then on the back. hopefully that is what you were asking.
Old May 25, 2010 | 06:39 PM
4getful2's Avatar
since he's got the 10's (more volume of air) on the rear, i wonder if it would float. my old kaw. 3 wheeler would ,with me off of it.
Old May 25, 2010 | 08:06 PM
rugnuts's Avatar
Old May 25, 2010 | 09:34 PM
vicdog's Avatar
The 4 wheel drive will engage when the button is in and the rear tires spin faster than the front. If the rears are shorter, you will always engage 4wd
Old May 26, 2010 | 02:19 PM
tw1st3d1's Avatar
Thanks for all the help, and clarification. I put my new tires on last night, and can't believe how much higher it makes it sit. I realy like the new stance. I hope to get some pics of it and it's twin sister tonight.
Old May 26, 2010 | 02:21 PM
tw1st3d1's Avatar
I can tell you from first hand expierience that it don't (too heavy) However my Honda 200 3 wheeler with the balloon tires on it will float with me on it, but it tips over really easy
Bratman2
Aug 6, 2022 01:42 AM
toonces
Oct 16, 2019 12:11 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
