alum. rims for scrambler 500, what fits ?
Old Jun 2, 2010 | 11:11 PM
dirtjunkie's Avatar
Default alum. rims for scrambler 500, what fits ?
im looking into getting a scrambler and one of the first things i want to do is change out the stock steel stamped rims........is there a quad that will interchange with the scrambler such as the predator without me having to buy special fit rims for this thing from ?
Also I once owned a warrior 350 with web cam, wiseco high compression piston, exhaust & jet kit, will i notice a drop in performace when going to the scrambler, that old warrior wouild haul some serious butt ?
One more question, will these things climb hills very well i weight 250# & dont want a slug or get stalled out ?
thanks in advance
Old Jun 3, 2010 | 07:43 AM
TLC's Avatar
TLC
Is it a 4wd? If so the front hub bolt pattern is a odd large diameter size. Make sure you stick with stock size tires,my friend when to 25" tires on his and it slowed the machines top end and acceleration.
The only hill that stopped him was steep ones which caused the ATV to flip backwards.
Old Jun 3, 2010 | 08:51 AM
3_Polaris_ATVs's Avatar
Wheels interchange with 75 % of all the Polaris quads. It is same 4x4 or 4x2 on gen3 quads. same as old trail boss, Trailblazer, sport and I am sure many more. Front and rear are different lug size and pattern.
Old Jun 3, 2010 | 08:58 AM
TLC's Avatar
TLC
If its a 4wd, the larger front hub casing with the locking Hillary inside is the cause of the odd bolt pattern,on 2wds the front and back have the same bolt pattern ,I think.
Old Jun 3, 2010 | 12:00 PM
No, 4x4 and 2x4s are the same. I just took the front wheels off my 400 scrambler parts quad and installed them on my friends 250 trailboss 2x4. Front and rear are diffrent. I am sure.
Old Jun 3, 2010 | 12:13 PM
jetmecanic's Avatar
Bolt pattern for the front should be 4/156mm and 4/4in on the rear.
I wouldnt change the size much in my opinion either.
This is from Mudthrowers.com wheel chart,
Scrambler 500 2x4/4x4, 97-08 (F)
23x7x10
10x5, 4/156
Scrambler 500 2x4/4x4, 97-08 (R)
22x11x10
10x8, 4/4
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
tysonbully
Sep 28, 2015 02:30 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
