Can't shift gears if bike's running 06 sp500
Old 06-20-2010, 09:14 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Between the sheaves of your primary where the belt rides at idle is a one way bearing. You should be able to spin it clockwise but not counter clockwise. Also note, Does your secondary spin while at idle in neutral. If so this tells me that the belt is grabbing when it shouldn't.
Old 06-23-2010, 02:29 PM
issac4049's Avatar
thanks for the info I'm going to look at it this weekend and I'll let you know what I find, thanks for the help.
Old 06-27-2010, 05:02 PM
issac4049's Avatar
I can spin the primary both directions and the secondary does spin in N at idle. So I guess the primary (one way valve) needs a rebuild, do you think that fixing the primary will also the fix the belt Grabbing
Old 06-27-2010, 08:47 PM
You say the primary spins both ways. I'm talking about just the bearing that the belt sets on when not revved up. If the bearing spins both ways it would have no affect on the belt grabbing. Although if thats the case it would affect your ebs. ALso need to check your belt alignment. Is the belt riding to one side or the other in the primary? Check for broken or loose motor mounts. Also might just need a shim added or taken out on the secondary.
  #15
Old 06-27-2010, 10:34 PM
UTU's Avatar
UTU
UTU is offline
Default no shift
quote: You say the primary spins both ways. I'm talking about just the bearing that the belt sets on when not revved up. If the bearing spins both ways it would have no affect on the belt grabbing. Although if thats the case it would affect your ebs. ALso need to check your belt alignment. Is the belt riding to one side or the other in the primary? Check for broken or loose motor mounts. Also might just need a shim added or taken out on the secondary.
I agree. check the belt see if it if favoring either side of the primary. Check the one way bearing with the belt off.idle should be around 1150rpm.
  #16
Old 06-27-2010, 10:50 PM
issac4049's Avatar
Ok I pulled the primary off and the oneway Valve does not spin or rotate I even tried to turn it with a rag and channel locks.
  #17
Old 06-28-2010, 07:00 AM
Kerbbirds's Avatar
primary needs rebuilt, takes special tools to get it apart,may have to go to dealer
  #18
Old 06-28-2010, 07:01 AM
Kerbbirds's Avatar
primary needs rebuilt, need special tools to get it apart, may have to take it to dealer
  #19
Old 07-05-2010, 08:44 PM
issac4049's Avatar
I bought a new primary because there wasn't going to be a big price difference after parts and labor and in stalled it on the bike, the secondary was spinning in N and it looked like the belt was favoring one side so I removed 1 of 3 washers behind secondary, started bike secondary did not spin untell I hit the gas. Then I removed 2 of 3 washers same thing did not spin untell I hit the gas... Then I tried it with all 3 removed same thing...?
I also double checked the motor mounts and there good.
  #20
Old 07-06-2010, 03:03 PM
Sounds like your on the right track now. If your secondary isn't spinning at an idle you should be able to shift gears without binding and grinding. So is your problem solved ? When you align the clutches (primary to secondary)try to get them so as the belt rides as close to center of your primary as possible. Watch your belt as the primary grabs it. Is one side grabbing before the other and so on. In a perfect world (as if!) the sheaves of the primary should grab both sides of the belt at the same time creating equal pressure to both sides of the belt.
txkevin
09-21-2015 02:02 PM
ROWALKER
06-15-2015 05:38 PM
chuck1177
06-07-2015 10:18 AM
winterwolf
ATC 3-Wheelers
06-03-2015 07:34 PM
Quick Reply: Can't shift gears if bike's running 06 sp500
