Polaris reliability
Old Aug 25, 2010 | 01:07 PM
  #51
Spdecat's Avatar
Originally Posted by Specta
When your ATVs hit 13,000 miles lets compare repair costs. I am one of those strange people that prefer dependability over "AWD" and a cushy ride.
I'll tell you that several of my friends ride Polaris ATVs due to their plush and cushy ride. Everyone that I know personally that has purchased a new Polaris within the last 2 years has has issues with them. I'm sure there are Polaris ATVs out there that have a great service and dependability record.
One has a 09 850 EPS XP with close to 5000 miles on it. One complete engine overhaul, the EPS unit has been replaced, one clutch assembly, 3 seized brake calipers and rotors and one broken spring. I'm sure his ATV is capable of going where I go but he wont take it in to those kind of places because it's more than he can do so his ATV has not been beat or abused. Being a die hard Polaris fan he will tell you to never buy a new Polaris without pruchasing the extended warrantee.
One friend bought a new 2010 RZR back in early July, with less than 200 miles on it the front diff came apart.
quote "Went for a ride up to Warm Lake last weekend and about 1/2 way back, the Rzr started feeling squirrely on corners, smelling hot and making a grinding noise. stopped and the front diff was smoking and leaking fluid. waited for it to cool some and then rode on home with no more trouble. Took it to the dealer on Thursday and they found a shaft bearing gone and the clutch plates in the diff all chewed up with metal shavings."
when he got it back this is what they said;
quote " Yep, it's fixed and running great. Found out that they used a plastic cage in the front diff, till 5/10/10 and had major problems with it."
A PLASTIC cage??? WTH??
Our brand new RZR 4 had the rear diff come apart with only 170 miles on it. We also have three 2009 RZRs and they all have about 5000 miles on them. We jsut got one out of the shop; top end rebuild, new clutch assembly, both driveshafts, both front axles, front diff OH, and ball joints. We have spent enough money on two of the RZRs that we could have bought a 4th one.
We also have 4 Rancher 400 ATs all with over 6000 miles on them, the crumby 3-wd drum brake ATVs. Total repairs on all 4 wouldn't cover 1/2 of the purchase price of a new one.
My good friend has a 2010 RZR 4 and he was bragging that he had 300 trouble free miles on it with no problems. While out riding the other day he used low range and now the entire machine has such a sevier vibration it's headed back to the dealer. Last week while we were out checking out a local forest fire he took his 2010 550 xp touring and with only 270 miles on it the right front axle started clacking and spitting grease out of the boot so it too is headed back to the dealer.
Where I live people put 1000s of miles on theri ATVs every year and without question Honda's are their number one choice.
Polaris has come a long way over the years but they are still on the bottom of the list as far as dependability goes, ask any ATV dealer owner to tell you the truth.
Is Honda the greatest ATV out there?? I doubt it and if I bought a new ATV today there's a good chance it wouldn't be a Honda. To me this isn't Honda vs Polaris it's just answering the OP question.
My 2008 Polaris 500 carb has 9000 miles on it , I'll post back next year when I hit around the 13,000 mile mark . As for the first 9000 miles except for a broken flywheel key the beast has been 100 per cent problem free , only routine maintenance needed . The most reliable toy I've owned to date I would of wasted my money if I would of purchased the extented warranty . I average 3000 miles a year on my POPO .
Old Aug 25, 2010 | 01:27 PM
  #52
Specta's Avatar
I knew there had to be atleast one good one out there somewhere.
Old Aug 25, 2010 | 02:34 PM
  #53
You know, you had the worst Polaris stories I've ever heard. These quads were all IDed by you, Specta.... Hmmmm.... The word "sabotage" comes to mind...
PS I saw an article in Dirt Wheels about getting more speed out of a Honda... :P Just being my juvenile self...
Old Aug 25, 2010 | 03:54 PM
  #54
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
It didn't break down at 200 miles, 300 miles, 400 miles, 500 miles, 600 miles, 700 miles ......
My point was I want to have fun riding now, and Honda doesn't cut it and neither does Yamaha.
Longevity of an atv is only useful to people who ride many miles or keep their atv for many years. Most people don't do either.
Old Aug 25, 2010 | 06:11 PM
  #55
Specta's Avatar
PS I saw an article in Dirt Wheels about getting more speed out of a Honda... .
You know that they're not telling you the truth, I don't think it's possible. LOL
Old Aug 26, 2010 | 10:33 AM
  #56
Spdecat's Avatar
There good as long as the letters EFI are not found on the machine , plain and simple equals reliability and the list below means nothing to you
Diagnostic "Blink Codes" Chart
21 - Loss of Synchronization
22 - TPS Circuit: Open or Short to Ground
22 - TPS Circuit: Shot to Battery
23 - RAM Error: Defective ECU
25 - Transmission Input - Invalid Gear
26 - Vehicle Speed Sensor - Implausible
41 - Air Temp Sensor: Open or Short Circuit to Sensor Voltage (ECU)
41 - Air Temp Sensor: Short Circuit to Ground
42 - Engine Temperature Sensor Circuit: Open or Short to Battery
42 - Engine Temperature Sensor Circuit: Short to Ground
45 - Barometric Pressure Sensor: Circuit Low Input
46 - Barometric Pressure Sensor: Circuit High Input
51 - Injector 1: Open Load
51 - Injector 1: Short Circuit to Ground
51 - Injector 1: Short Circuit to Battery
52 - Injector 2: Open Load
52 - Injector 2: Short Circuit to Ground
52 - Injector 2: Short Circuit to Battery
54 - Engine Temperature Lamp: Open Load
54 - Engine Temperature Lamp: Short Circuit to Battery
54 - Engine Temperature Lamp: Short Circuit to Ground
55 - Diagnostic Lamp: Open Load
55 - Diagnostic Lamp: Short Circuit to Ground
55 - Diagnostic Lamp: Short Circuit to Battery
56 - Pump Relay: Open Load
56 - Pump Relay: Short Circuit to Ground
56 - Pump Relay: Short Circuit to Battery
58 - Cooling Fan: Open Load
58 - Cooling Fan: Short Circuit to Ground
58 - Cooling Fan: Short Circuit to Battery
61 - End of Diagnostic Check
Old Aug 26, 2010 | 02:47 PM
  #57
unit6666's Avatar
You know I had a 1988 ford escort lasted me 267000 miles...I will be the first to tell you only .0000000001 % of them lasted that long... yet I don't think it is a realiable car Hmmm... I am far to logical..
Old Aug 27, 2010 | 02:10 PM
  #58
RticKwad's Avatar
Runs Stealth!
Some other factors come to mind as I read this thread and that is RIDING STYLE. I know my friend rides his Polaris machines much HARDER then me. He told me he won't change his front diff/trans fluid (2007 SP500) yet b/c he feels he is okay based on the fluid color etc. He rides more then me, runs water and mud more then me, really puts his machines thru its paces.
I get critized from a number of friends on my "Shed queen" why? Well, I can count on how often I get to ride, maybe 5 times in a season and I have a 2008 with less then 300miles and low hours. Multiple fluid changes, tuning etc.
Lack of PM + RIDING ABUSE + Storage practice (exposed to weather, it matters for the carbs) is just a few factors as well for why these machines may last longer then others.
So it does come down to how well you take care of your machine and how you ride it too. - IMO
Regards,
R'
Old Aug 27, 2010 | 08:37 PM
  #59
bitterfitter's Avatar
I had a completely bare bones 82 Escort (No power anything, not even power steering, no AC, no radio, 1.6 liter 4 and a 4 speed stick) go 230,000 miles.. It was running when I pulled the head to put in another 82 Escort with lower miles. . That takes it over 0.0000000001 %
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
Nondem
Feb 22, 2020 12:20 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
