Carb Main Jet E clip location
Old Sep 5, 2010 | 08:47 PM
Nandy's Avatar
Default Carb Main Jet E clip location
My 300 has the 5dp7 jet and the book says to place the e-clip on the 3rd ring but it dont say if you count the rings from the direction of the jet tip (bottom) or from the beginning of the jet (top). I cannot trust the location that it is now as the guy that had it before dont know his head from his butt.
Thanks!
Old Sep 5, 2010 | 08:51 PM
Count from the top!! OPT
Old Sep 6, 2010 | 09:44 AM
Nandy's Avatar
Thanks!
Old Sep 6, 2010 | 04:25 PM
Overdrive's Avatar
Most run better if you put it in the second from the top. Also open the air screw one half turn out from where it is now.
Old Sep 7, 2010 | 09:03 AM
Nandy's Avatar
That on itself will make it run leaner, of course adjusting the air will probably compensate. Interesting. I will set it up as the factory indicates run it a bit then make the change.
Thanks!
Old Sep 7, 2010 | 12:49 PM
MECHANIKE's Avatar
what i do is start with the clip in the middle, then start enriching it by lowering the clip(which raises the needle)once it stumbles go back one and your set.
Old Sep 7, 2010 | 01:36 PM
MECHANIKE's Avatar
GregM
Mar 6, 2018 06:53 AM
Captjay
Jul 23, 2015 12:33 PM
toonces
Jul 21, 2015 02:40 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
