oil drain and fill
Old Sep 25, 2010 | 08:51 PM
polcat1p's Avatar
Default oil drain and fill
i want to change the oil in my 99 scambler, how do i drain and fill? i know where the dip stick is. Do i need a snake funnel?
thanks
Old Sep 25, 2010 | 09:06 PM
Remove 9/16" drain bolt from oil tank and drain. You can also crank engine after tank has drained for 20 seconds ONLY and sump will drain into tank and out into drain pan. Leave old filter on while doing this,then remove filter,replace with new one and add 2 quarts 0-40 Mobil 1 OR PS4 plus Polaris oil. You can also remove the oil line going into back of the tank to check/clean the screen,BUT if oil has been regularly changed the screen should be clean,BUT this is up to you! Long necked funnel helps!! ( OR if you are talking about a 400 Scrambler 2-stroke counter balancer oil,THEN there is a 10mm drain plug under engine to drain,ONLY holds about 75cc 30 weight oil.) Hope this helps. OPT
Old Sep 26, 2010 | 11:22 AM
TLC's Avatar
TLC
LOL ,thats how I do it also.
On the Fuji Motor make sure the oil is Sythetic 0w-40.
ReconBayou
Oct 31, 2022 05:37 PM
Alex G.
Sep 11, 2017 11:38 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
