2004 Sportsman bog
I have a 2004 Sportsman 700 EFI. It will start and idle great, when you put it on the road it runs good until you hit full throttle, then it will bog. When it bogs you can turn the key off and on quickly and it will run you up to 50 mph. It will run like that until you slow down then it will start over with the bog situation at full throttle.
Any ideas what is wrong?
Thanks
Thanks
Sure its not a 2004.5 that my be on the ECM (Brain Box) recall list? Polaris Industries Recall of Select Model Year 2004.5 and 2005 Sportsman and 2005 Model Year Scrambler ATVs
A screwy ECM make them do all kind of strange things.
They have them listed on the recall. 2004.5 = 2005 remember.
2005 Sportsman 700 A05MH68AK
A05MH68AN
A05MH68AP 4XAMH68A*5A 349720-349789, 351776-352060, 353253-353487, 356181-356390
4XAMH68A*5A 360901-361245, 362707-362764, 363575-363646
4XAMH68A*5A 349130-349719, 351591-351775, 353488-353729, 355836-356180
4XAMH68A*5A 360781-360900, 361286-361545, 362582-362706
4XAMH68A*5A 362597-362609
A05MH68AN
There is a recall on the breather tube that goes from the air box to the crank case breather, the ones with the filter get a crack in the filter causing a vacume leak, the new ones have no filter. I know it sounds stupid but my old 700 did the same thing, replce the line, its free with recall and try it.
bradco
08-21-2015 08:11 PM
Stirling
08-09-2015 01:49 PM
