Front gearcase pinion leak
Old Nov 15, 2010 | 06:43 AM
toyoman28's Avatar
I'm going to try the John Deere seal kit (MIA10654). Only $15 so no big loss if it doesn't work. I can't find any info on whether it will work on an ADC unit or not, but hey it's worth a shot.
Old Nov 15, 2010 | 07:11 AM
Kerbbirds's Avatar
let us know if it works.
Old Nov 15, 2010 | 10:50 PM
toyoman28's Avatar
part is on order...will be here in 2 days.
Old Nov 16, 2010 | 01:30 PM
toyoman28's Avatar
Default Found my problem!
In preparation for the front pinion seal parts getting here tomorrow, I tore into my front gearcase today and found something pretty interesting if not dissappointing.
It appears that some of the sealant Popo used to seal the ADC coil wires into the assembly plate got wrapped up into the seal lip and was causing the leak. A case of sloppy workmanship there and I'm not at all impressed. They used too much sealant or were careless with it. Check out the pics.
I'll probably put it back together and see if it still leaks before I replace anything. There is a possibility that the strip of sealant rubbed the seal to cause permanent damage to it, but it looks okay to the naked eye.
Attached Thumbnails Front gearcase pinion leak-08-sp500.jpg   Front gearcase pinion leak-08-sp500a.jpg
Old Nov 16, 2010 | 05:43 PM
  #15
toyoman28's Avatar
Well, it's back together (minus the chunks of RTV) and so far no leak with a few trips around the block. At least I'll have the seal kit on hand just in case...
Old Nov 17, 2010 | 07:19 PM
  #16
Kerbbirds's Avatar
Ill bet you can get that seal from the parts house, if you can get it out without destroying it, it also looks the same as the older ones so I'll bet the john deer one will work.
Bratman2
Aug 6, 2022 01:42 AM
carolinabomb
Jul 26, 2015 08:40 AM
TLC
Jul 25, 2015 02:24 AM
tporath
Jul 11, 2015 12:31 PM
traumajunkie
Jul 5, 2015 03:03 PM
