How to fix Polaris exhaust problem?
Old Nov 20, 2010 | 08:41 PM
Hawkeye_State's Avatar
Default How to fix Polaris exhaust problem?
I have a 1995 Polaris 425 4x4 magnum. It runs well, but the exhaust gets very hot. The exhaust pipe runs close to the body on the right side, and has gotten so hot that it has slightly melted the plastic. I've use an exhaust wrap in the past, which worked okay. Is there a better way to keep the exhaust pipe from melting the plastic on the body?
Thanks,
Dan
Old Nov 20, 2010 | 11:24 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Exhaust wrap and reflective heat tape are the two best ways I know of to help with your problem. Another thing that could be causing excessive heat is running too lean. Some models just have the tendency of running hot, like some of the 800's.
Old Nov 21, 2010 | 07:23 AM
JCDEYO25's Avatar
Some guys have the pipes coated such as Jet Hot coating to keep them cooler...Not cheap but works..
John
Old Nov 21, 2010 | 07:45 AM
ftwflh's Avatar
My old 425 did the same thing.I just put more heat tape on the heat shield and learned to not let my leg get on the cover.If you burn a hole in your cover drop me a pm I have a couple good ones
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
joshuafromny
Jun 22, 2015 05:30 PM
polaris scrambler00
Jun 20, 2015 08:49 AM
alex_2011
Jun 9, 2015 10:12 AM
blaze_master
May 26, 2015 11:18 AM
