High idle and oil
Old Nov 24, 2010 | 04:01 PM
4getful2's Avatar
you might have too much slack in the cable, now causing the electric throttle control to engage. you may want to po the top off of the thumb throttle and look inside and adjust your slack to where those ttwo soldered wires are not touching, you should have a 1/16-1/8" gap, then do your idle-carb.adjustments then go back and reset air gap adjustment again
Old Nov 25, 2010 | 09:17 AM
ajfetterman's Avatar
Thankyou everyone for your help!! I plan on playing with it later today and see what I come up with.
Old Nov 26, 2010 | 09:51 AM
Ok I can only get it to start on starting fluid which leads me to believe that its a fuel issue. I have plenty of flow when I take off the fuel line at the carb, so Im a bit puzzled. I havent adjusted the choke because mainly Im not sure how and also I havent touched it and it ran fine before.
As for the electronic throttle control I cant seem to adjust it enough to where it doesnt touch I run out of threads on the adjustment screw at the handle bars. Is there a way to just bypass those wires? Right now I have to tape the thumb lever to the hand grip so they dont touch as Im trying to pull start it.
Again Im a quad novice and maybe Im missing something simple here but I dont know for sure.
It does idle decent now when I use the starting fluid to turn it over but doesnt stay running long enough to do a proper job.
Sorry for being a pain, just want to get it running before it gets too cold to be in the garage.
Thanks
Old Nov 26, 2010 | 10:02 AM
I should also mention that when it is started and I hit the throttle it act like it floods out and stalls.
Old Nov 26, 2010 | 10:41 AM
  #15
kcaves's Avatar
the needle and seat in the carb might be bad or ur float is stuck if ur oil is high, smell ur oil and if it smells gassy than it is either the needle and seat or the float
Old Nov 26, 2010 | 07:36 PM
  #16
Kerbbirds's Avatar
You can take up the slack on a 2 stroke on top of the carb, screw the handlebar adjustment together and adjust the slack out on top of carb,
Divergent12
Aug 19, 2023 05:26 AM
Cummins Driver
Sep 11, 2019 01:22 PM
donintennessee
Aug 19, 2015 02:22 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
MNatv89
Jul 7, 2015 11:36 AM
