'02 Magnum 500 No Reverse!!
Old Nov 23, 2010 | 09:41 AM
AllTerrainJunkie's Avatar
Default '02 Magnum 500 No Reverse!!
Hey can any of you guys shed some light on this?? My magnum 500 won't come out of high gear, even when the neutral light is on the cluster, if I try to put it in another gear it simply won't move. Also the 4x4 doesn't always work, does this have anything to do with the speedo? This is very frustrating as it is my only means of plowing my driveway. Pls help?
Old Nov 23, 2010 | 02:32 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. can you move the gear selector w/ the engine turn off? will it change gears like this? if not it sounds like maybe something like a bent shift fork or broken pin inthe transmission is the issue(just a guess w/ out looking). not sure on the magnums, but on the sportsmans if the speedo doesn't work then the awd won't in some cases as the awd is ran through the speedo.
Old Nov 26, 2010 | 09:55 AM
Yes I can move the gear selector although it is still in gear. I think I saw a post about taking the cover that the linkage runs through on the tranny off and cleaning it. Man, I really love this wheeler but it is a huge pain in the neck to work on.
Old Nov 26, 2010 | 07:47 PM
Kerbbirds's Avatar
Take the rightside cover off and see if both rods are moving the levers on top of tranny when you move the shifter if they are moving but its still in forward, unhook them one at atime from tranny, get some channel locks and try to shift the tranny manually let us know what happens
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Gwolf228
Feb 18, 2017 01:36 AM
r1pilot83
Sep 27, 2015 07:38 PM
Sep 9, 2015 06:57 AM
