New battery not staying charged on 95 Xplorer...What gives??
If I run the lights while I plow my battery gets really weak...What keeps the battery charged on a wheeler?...Im pretty sure they dont use an alternator...so what do they use in place of one to charge battery and how can I check it and where is it located?..Thanks
check the voltage at the battery as mentioned to make sure your pushing high 13 volts. you have to understand that the winch runs strickly off the battery and your also using the lights so it uses alot of juice form the battery. the stator which produces the the power isn't designed for high voltage out put so it can't keep up w/ the demand you put onit very good. this is only if the unit is working correctly.
cody500ho
14
08-14-2015 05:03 PM
