Snow and ice on the atv
Old Dec 19, 2010 | 02:19 PM
Wenty's Avatar
Originally Posted by hallj86
I dont have a heated garage and after plowing/ icefishing how do i get the snow off? Does anyone have a problem with their brakes freezing up mine are almost none exsistant.
I plow and ice fish all winter here in MN and my Xplorer sits in a unheated garage. I've never had a problem. I do clear the struts, A arms, winch, cv boots, etc off every once in a while. I have several buds who deal with the same thing...they don't have any issues either.
Although...if your worried about it and want to melt it off...warm the atv up good...throw a tarp over it with a heater going under the tarp. A few days ago I needed to change chains and sprockets. My machine had quite a bit of ice accumulated on the under side, swing arm, a arms, struts...etc. With it completely tarped and my "sunflower" mr. heater going my atv was completely thawed and dry in about 6 hrs.
My machine probably won't be thawed again until spring unless It needs maintenence...I'm not worried about it.
P.S....headed out to a local lake in a few minutes to pound some crappies!!
Wenty
Old Dec 19, 2010 | 04:34 PM
switzomatic's Avatar
Never thought of tarp thing-awesome idea! I do thaw mine out completely in the garage occasionally but for the most part just keep the snow cleared out as it builds up. I also remove the cv guards for the winter so it doesn't get as packed in there. Never had any problems yet.
Old Dec 19, 2010 | 11:14 PM
Mongrol's Avatar
"Official Site Skeptic"
Originally Posted by EFF_Rubicon
before plowing i try and spray the boots and stuff that might be damaged
with pb blast or wd-40 snow doesnt stick
Over the past 4 yrs, I have tried every chemical/substance that will shoot out of a bottle or spray from a can, to keep the "A" frames filling with ice and snow. Vegetable oil (Pam), baby oil, silicone, car wax, WD40, you name it I've tried it with no sucess.
It appears that temp and moisture content in the snow is the biggest factor and that changes daily.
Old Dec 20, 2010 | 01:49 AM
CaptainQuint's Avatar
My garage is unheated but unless it is ungodly cold outside a pretty good amount of snow melts when I come in from plowing or playing. The built up heat from the ATV raises the temp just enough to melt a pretty good portion of the snow and ice. Makes a glorious muddy mess on the garage floor.
Old Dec 20, 2010 | 06:01 AM
  #15
McNabb100's Avatar
You might be able to blow it off with the air from an air compressor.
Old Dec 20, 2010 | 08:13 AM
  #16
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default Depends on climate..
I guess most of these tips will not work in Canada.........
...Caper.....
Old Dec 20, 2010 | 08:31 AM
  #17
JCDEYO25's Avatar
...Caper.....
Looks like the only solution for you Caper is to move closer to the equator...lol...
John
Old Dec 21, 2010 | 12:01 PM
  #18
Big600twin's Avatar
I have also used a hair dryer and it works great. Nothing worse after a day of ice fishing to then come home and have the machine frozen solid for the next trip.
Irishman301
Sep 23, 2015 01:47 PM
stcspiderman
Sep 13, 2015 05:15 PM
awer1968
Sep 8, 2015 11:02 AM
MooseHenden
Polls
33
Aug 28, 2015 04:56 PM
cornermike
Jul 8, 2015 11:44 PM
