ignition issue
Old Jan 3, 2011 | 08:58 AM
94harley's Avatar
Long shot but if I remember correctly, the stator can be installed one hole off(the three screws) Is it possible it's off a one hole? I'm not sure if it would even cause an issue like your having if it was off, but I'm trying to get that 50$ check! JK. Can you e-mail a pic of the stator without the flywheel installed?
Old Jan 3, 2011 | 09:27 AM
whalebus's Avatar
cam looks good.wouldnt it have been running rough before if it was a cam issue ?I replaced the plug and nothing.Im going to remove the exhaust real quick and see if its clogged or something.I"ll be back
Old Jan 3, 2011 | 01:54 PM
whalebus's Avatar
well Im getting there.walked out this morning and decided to pull the recoil starter and it FIRED UP!when I was putting the valve cover back on I found a 4 gauge ground wire that was broken that went from the frame to the haed,so replaced the wire and nothing.Get this,it cranks using the pull start but want crank with the starter.WTH I charged the battery and still nothing.Once again im stumped.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
