97' Xplorer 500 Carb pulling away from motor
Old Jan 14, 2011 | 10:27 AM
dwright's Avatar
Unhappy 97' Xplorer 500 Carb pulling away from motor
I have a 97' Polaris Xplorer 500 and since I pulled the carburateur off and put a new needle and cleaned it I have had troubles with it being too far away from the motor adapter so twice now it's pulled away from the motor causing it to die. I pulled the rubber mounts and tried to push the carb closer inside the rubber motor adapter and it doesn't go in as far as the groove. Does anyone have any ideas on this? Should I try sliding the whole motor back?
Old Jan 14, 2011 | 10:44 AM
TLC's Avatar
TLC
Get the carb into the motor side first and hose clamp it tight, then fool with the tube between the air box and carb instead. The airbox tube is long enough to have room to slide back and forth between the airbox and carb.
Old Jan 14, 2011 | 10:45 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
ummm- tighten the carb intake boot???
or- make sure your filter box is installed properly, allowing the carb to seat in the boot in the first place.
Old Jan 14, 2011 | 11:58 AM
94harley's Avatar
I've seen that several times on older 500's. Take about 1/8 inch thick of washers and get some longer screws(the screws that hold the carb to the bracket that is mounted to the frame) Put the longer screws in with the washers between the bracket and the carb and it will quit popping out of the boot.
Old Jan 14, 2011 | 01:57 PM
Overdrive's Avatar
That is correct. This is a common problem and he just told you the correct fix.
Old Jan 19, 2011 | 04:02 PM
dwright's Avatar
Thanks. I put the washers in and it worked.
Shooterj2003
Jun 21, 2015 07:51 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
momofo
May 27, 2015 12:06 PM
JackOReilly
Dec 7, 1999 09:12 AM
