burning oil
Old Jan 21, 2011 | 11:38 PM
07 400's Avatar
I have seen some arctic cats atv with 12,000 miles on it and never used a drop.does your atv blow blue smoke out the exhaust when you rev up motor in neutral if it does oil is going by the rings. I would say if you burn a little oil it is ok. check the breather on motor is open also.
Old Jan 22, 2011 | 08:18 AM
snow racer's Avatar
Ya it might be the rings Do a comp test
Thank you for serving and i hope you come home safe.
Old Jan 22, 2011 | 04:52 PM
t-hearn's Avatar
I haven't done a compression test on it yet but i will run it over to my buddy's place, it seems to run really well and it dosent seem to smoke at all.
Thanks for all the well wishes, im not military i am going over as a civilian to work on the base for the military. it is true though all of our troops are real heroes, there the reason our country is as great place to live.
Thanks for all the help
tom
Old Jan 22, 2011 | 05:52 PM
TLC's Avatar
TLC
Originally Posted by t-hearn
Thats why i had to do a quickie oil change in the bush, noticed it was low and i know not to mix reg with synthetic so i changed the oil in the bush.
Im not too familiar with 4 stroke operation(used to my sleds) when they get up there in age is it normal for them to burn some oil?
Says right on the Amsoil Full synthetic 0W-40 label. "Compatible with conventional oil"
Who told you Synthetic and regular oil cant mix? Here a link if you still do not think so. Thats what synthetic blends are. http://www.ehow.com/facts_6853739_ca...-regular_.html
Amsoil ad. http://www.amsoil.com/StoreFront/aff.aspx
Compatibility
AMSOIL Formula 4-StrokeŽ PowerSports is compatible with conventional and synthetic motor oils.
Also for those who think Synthetic hurts wet clutches.
Wet clutch compatible. Contains no friction modifiers. Broad viscosity range makes it excellent for use in both hot and cold weather conditions.
Old Jan 22, 2011 | 05:58 PM
  #15
t-hearn's Avatar
I have always been told that when synthetic and reg oil it gets like milky, never seen it happen but always been told not to mix so i never did.
Old Jan 22, 2011 | 06:00 PM
  #16
Kerbbirds's Avatar
I had a n 03 -700 , had 5600 miles on it when I sold it , never used a drop of oil, used Castrol Syntec 5-w30 in it since it was new, maybey it just doesnt like the oil your using. I have a 97 dodge ram with a 360, got around 100,000 miles on it and I decided to try the High Milage , synthetic blend. Valvoline, it used a quart in under 1000 miles , went back to regular valvoline , which is what its always had, has not used any more since
95scramblerruben1033
Sep 23, 2015 06:29 PM
caveeagle
Sep 19, 2015 01:20 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
bvolks
Sep 13, 2015 12:57 PM
Elkaholic
Sep 6, 2015 02:44 PM
