Valve cover gasket...
#21
John
#23
your right that hose is a pain but that hose gets saturated with oil and it starts leaking from that slit and runs along the hose down to the breather on the valve cover and it drips right there i'm almost sure if you replace that hose and clean that area up it will fix your leak
#25
Just wanted to update on my oil leak...Finally got around to tearing machine apart and replacing valve cover gasket...That's what I narrowed it down to...Also had a bad water pump cover gasket leak to, put new one on as well, torqued all bolts to spec and all seems well..Oh yea, threw on a new drive belt too and glad I did...Original belt was gettin cracks in it..Gonna carry it with me on rides as a spare...Flushed coolant too...No leaks so far...
John
John
#26
John
John
#27
John
carid
Sep 14, 2015 03:40 PM
Lou Domenech
Sep 11, 2015 06:35 PM
