Need your thinkin caps.
Old 05-03-2011, 09:11 PM
Jaster94's Avatar
is there any way you can duplicate the situation? like, up on blocks and use a ratchet strap to compress the front end? do you reckon that'll simulate the downhill experience? and maybe help you troubleshoot it from the ground beside it rather than on top riding?
Old 05-04-2011, 12:25 AM
bigcam400's Avatar
could it be the front brakes??? mine make grindin nosies in reverse an when wet,..an every now an then on step hills???
Old 05-04-2011, 04:21 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I did set the brake and get off to inspect on a steep hill and found nothing when it starting the grinding noise. Everything looked fine. And I don't think it's my brakes. I never touched the brakes on the times it was grinding and they've never uttered a sound other than the occasional squeak in over a 1000 miles. Thanks for all the replies but this one will probably be one of those things I'll have to figure out with time since it has done it with no rhyme or reason. We'll see next time out If I accidentally fixed it. fingers crossed.
Old 05-10-2011, 07:40 PM
Jaster94's Avatar
did you fix it?. what did you find out?
  #15
Old 05-11-2011, 08:39 PM
Not sure? As stated before I went through every moving part and scratching my head. Everything runs great on flat and moderate hills but I'll find out soon enough. I just got done loading up for a 3 day trip to haspin acres this coming weekend where there will be plenty of rough terrain to test it out on. Wish I had time to do some thorough testing pre-trip but haven't been getting home till late most nights now that construction is in full go mode. Fingers crossed!
buddieboy
12-09-2016 05:50 PM
bnt5
08-07-2001 09:54 PM
MILESONFIRE
07-17-2001 08:00 PM
Camo-man
02-16-2001 10:52 AM
Quick Reply: Need your thinkin caps.
