How do I set the Compression
Old May 5, 2011 | 10:43 AM
Rhea's Avatar
Default How do I set the Compression
How is going guys I need help fast .I want to know how to set the compression on a Polaris 2001 250 trail blazer. I looked at it and could not figure it out .The guy I got it off of sayed it was at 90 some thing pounds and it will not start . so I am asking you for your help
Old May 5, 2011 | 11:17 AM
scootergptx's Avatar
Supersock
Hired Gun!
I would say it's due for a new top end. No real 'adjustment' for compression.
Old May 5, 2011 | 11:18 AM
BlackRaptor's Avatar
I'm guessing your talking about engine compression.You can't set the compression on an engine. it's not a setting it's controlled by the piston clearance and a few other factors.
If your engine only has 90PSI your going to have to rebuild the top end to get the compression back.
Old May 5, 2011 | 12:04 PM
garyc660R's Avatar
Rhea, make sure your timing / valve adjustment is correct and then check cranking compression.
Old May 5, 2011 | 12:12 PM
Supersock
Hired Gun!
2 stroke.
Old May 5, 2011 | 12:39 PM
garyc660R's Avatar
Originally Posted by Scootergptx
2 stroke.
lol damn I knew that as well. Please refer to Blackraptor's response.
Old May 5, 2011 | 02:43 PM
Rhea's Avatar
Guess your guys are right time to rebuild it and thanks for the help .YOU guys have saved me a ton of time
Old May 5, 2011 | 02:49 PM
Supersock
Hired Gun!
Looking at my reply, I guess I should say there is an adjustment. Just not a **** or valve you can turn. Milling the head, different bore, different type of piston, etc... can vary the overall compression.
But in your case, low compression means new top end.
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
