2000 325 Trail Boss rear bearing
Manual will explain best,but in a nutshell, jack up right under frame to lift tires off ground, remove tires,loosen the 2 axle housing bolts,you can use a large pipe wrench to turn the rear axle housing forward to loosen chain,remove RIGHT axle hub,remove sprocket guard bolts,remove sprocket bolts and can just let set there,the guard can slide off axle, remove snap ring on axle nut retainer cap on RIGHT side. Slide cap and snap ring off axle,remove main axle nut against housing. Go to left side,remove brake caliper,loosen rear brake rotor and hub,REMOVE caliper mounting bracket.With sprocket still in loose chain you can slide axle out from left side. You May have to remove snap ring on LEFT side,retainer cap,and nut also for room to remove the caliper bracket,Plus there is a snap ring INSIDE the LOCKING SPACER on left side that may have to be removed and slid outwards? (been a while since I removed one).Chain,sprocket can just dangle and can be lifted up to change bearings,seals. Hope this helps you get started,BUT I may have forgotten something(I'm ALLOWED since this off the top of my head!) I stress getting a MANUAL! PLUS you can see a break down on parts at Pure Polaris Parts Catalog online. OPT
You have to sometimes pry a little around the retainer cap to remove it depending on how much dirt and mud!!(retainer ring HAS to be removed first!) OPT
I had a custom made 3" x 3' pipe with a socket welded in place and a 1/2" adapter welded on the other end for use with an impact I could just impact em off! Before I had this,I removed em in TWO different ways. With machine jacked up and a big pipe wrench over the nut with the handle on the concrete,then place in REVERSE slowly give it gas,would usually break the nut loose.The other way if heat and the wrench didn't work,I would just air chisel the nut lose and replace with a new one! OPT
Frisky2050
04-09-2020 11:19 AM
