gas smell
Old Sep 22, 2011 | 04:33 PM
irinman2424's Avatar
Default gas smell
after the Minnesota trip I have noticed when I ride and get it up to temp I am smelling raw gas its not there when I ride a short distance what should I look at to correct this there is not obvious dripping or wetness anywhere that I can see
Old Sep 22, 2011 | 04:41 PM
Check your tank vent line for bubbling out gas? Could be smelling gas fumes from the front especially if tank is completely full. Plus check the air box for gas. Just a start. OPT
Old Sep 23, 2011 | 06:27 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Ditto, Mine does drip a little gas down on the frame when the tank is completely full but not noticeable once the level begins to drop. Although it's not a problem for me, I always thought the check valves were supposed to stop gas from escaping and just let air in to equalize pressure inside the tank? Or are my check valves bad?
Old Sep 23, 2011 | 10:55 AM
ATPmike's Avatar
Check the gas cap. I get leakage from around the cap. I pulled the the side cover and found the wet spot from there.
Old Sep 30, 2011 | 05:05 PM
pwssr's Avatar
I had the same issue - turned out to be both of the fittings on the bottom of the gas tank (that the hoses connect to) were weeping. When I tried to tighten them a little, they were screwed in as far as they could be (tapered pipe thread). I drained the tank, removed them, cleaned everything up, put some {plumbers} wicking on the threads as well as a little sealant. Screwed them in until they were just snug and let things cure for a couple of days. No more raw gas smell!
Old Sep 30, 2011 | 06:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check all the fittings and vent lines for leakage.
bigred20653
Oct 2, 2015 10:05 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
