How to remove handle grip?
Old Oct 13, 2011 | 07:57 AM
BigWadeS's Avatar
Default How to remove handle grip?
So I need to get to my on/off switch cluster and need to remove my handle grip. What's the best way to do that? Heat gun? Also what do you use to re-attach it back in place.
Old Oct 13, 2011 | 08:19 AM
moerules's Avatar
if you have an air compressor with a blow gun or air fitting just blow air into hole in end of grip swells right up and off she comes!!! surprising how easy it makes it!!
Old Oct 13, 2011 | 09:57 AM
awsume800efi's Avatar
yup air is the easiest way by far stick your air gun in the hole and plg the other side with your finger just reverse it to put them back on
Old Oct 13, 2011 | 11:06 AM
EPI Shawn's Avatar
just be carefull not to use to much pessure iv had a couple of sofer grips blow up like a baloon trying to take them off.
Old Oct 13, 2011 | 11:48 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
x2 - compressed air will slip them right offand back on again.
you might have to use a heat gun if they were cemented on.
Old Oct 13, 2011 | 12:01 PM
scootergptx's Avatar
Supersock
Hired Gun!
Might also want to use a little hair spray on the bars when you put the grips back on. Or if you have a wife or girlfriend that frowns on that sort of thing, you can buy grip glue.
Ashley S
Feb 18, 2024 08:56 PM
Cantbuytime
Aug 16, 2015 09:13 PM
erntee61
Aug 9, 2015 02:54 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
