2005 polaris magnum 330 4X4
![Confused](https://atvconnection.com/forums/images/smilies/confused.gif)
If it only runs with the choke on then sounds like you need to check the carb jets again,plus did you just try to clean or did you replace the needle and seat? Check for any black specs in the carb bowl also ( fuel line breakdown). If you get it running right use some Marine Stabil and you wont have to worry about fuel breakdown,water,etc. OPT
Shifts
14
07-13-2015 08:41 AM
