1996 Xplorer
Having problems of motor flooding out and stalling out on trails. Put it in low range and runs better. On open road has plenty of power. Ceaned carb and not better.Would compression cause this? Any help would be appreciated
Welcome to the forum! Did you replace the needle and seat when you cleaned the carb? Plus float arms and pins are bad about wearing out on the vibrating 2 stoke carbs and usually aren't replaced when carbs are gone into. Could be the problem along with float level if you didn't check it out. You can also check compression,should be a minimum of 115 psi,better if it has more. OPT
MeadowlarkFarm
Nov 27, 2019 08:40 PM
